X570 NVMe query?
Man of Honour
8 Nov 2007
Outer Space
Hey guys,
I've recently bought the Asrock X570 Taichi which has 3 NVMe slots, now are these driven from the X570 chipset or are they controlled from the CPU?
In other words, do I need a 3xxx series CPU to use these or will a 2xxx CPU work 100% with the 3 drives?
There'll be one using cpu lanes and the rest will use chipset lanes. I'd expect all to work at gen 3 speed rather than gen 4, but can't say for sure.
Hey guys,
Hey, with a 2000 series CPUs two M.2 slots will work at Gen 4x4, while the first M.2 slot will work at Gen 3x4. https://www.asrock.com/mb/AMD/X570 Taichi/#Specification
- 8 x SATA3 6.0 Gb/s Connectors, support RAID (RAID 0, RAID 1 and RAID 10), NCQ, AHCI and Hot Plug
- 1 x Hyper M.2 Socket (M2_1), supports M Key type 2242/2260/2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen4x4 (64 Gb/s) (with Matisse) or Gen3x4 (32 Gb/s) (with Pinnacle Ridge and Picasso)*
- 1 x Hyper M.2 Socket (M2_2), supports M Key type 2260/2280 M.2 PCI Express module up to Gen4x4 (64 Gb/s)*
- 1 x Hyper M.2 Socket (M2_3), supports M Key type 2230/2242/2260/2280/22110 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen4x4 (64 Gb/s)*
*If M2_3 is occupied, PCIE5 slot will be disabled
Supports NVMe SSD as boot disks
Supports ASRock U.2 Kit
You can look on the motherboard manufacturers page for the board. Under storage specifications.
Thanks, so this is gen 3?
Intel® X299 Chipset :
1 x M.2 x4 Socket 3, with M key, type 2242/2260/2280/22110 storage devices support (SATA & PCIE 3.0 x 4 mode)*3
1 x M.2 x4 Socket 3, with M key, type 2242/2260/2280/22110 storage devices support (PCIE 3.0 x 4 mode)*4
8 x SATA 6Gb/s port(s)*5
Support Raid 0, 1, 5, 10
Intel® Rapid Storage Technology supports
(Intel® Core™ i9 10000 X-Series CPU) :
2 x M.2 x4 Socket 3, with M key, type 2242/2260/2280/22110 storage devices support (PCIE 3.0 x 4 mode)
Intel® Rapid Storage Technology Enterprise supports
(Intel® Core™ i9 9000/7000 and i7 9000 X-Series CPU) :
Intel® Rapid Storage Technology 15 support
Intel® Optane™ Memory Ready *6
It does say that, but the cpu uses 4 lanes to communicate with the chipset. It'd be 4 gen 4 lanes on Zen 2 vs 4 gen 3 lanes on Zen+. So there isn't the bandwidth there to run the drives at gen 4 speeds.
Interesting, doesn't the M.2 module communicate at 4x4 speeds with the memory modules or other 4x4 devices through the chipset independently from the CPU?
Why would data go directly from the SSD to the CPU?
