Still waiting for that review!![]()
Sorry!
Cooking has been so much better, but I'm guessing a lot of that is down to my new hob as well, and yes it is induction. My old induction one had finally bitten the dust. It's an AEG IKE64450FB with Maxisense, so it detects the size of the pan heats the correct size for the base which helps with even heat spread.
So I did an experiment last night with the P boost setting to quickly heat water and tested 3 pans, all 16cm with 500ml of water.
Pan 1 : Old generic non-stick pan with metal base for induction. Even heat across the pan base, time to boil 1 min 55 secs
Pan 2 : S.Steel pan with metal base (old and knackered, base has started to lift off - these are what I replaced). Visibly smaller contact patch of heat due to knackered base, time to boil 3 mins +
Pan 3 : Elite Tri ply S.Steel pan. Even heat across the base, time to boil 1 min 20 secs
So yes, the speed of heating from the Tri ply is very very good leading to a significant decrease in the boiling time in that experiment. Also the distribution seems very even (but like I say, my hob is facilitating that too tbh), and the sides of the pan heat up extremely well too.
I haven't found the lid handles getting hot at all really, though the longest they have been used so far is about 20+ mins of boiling. The glass lids do steam up of course, but enough steam escaped to still allow visibility of the food.
I did notice the lid on the 18cm one 'rattled' due to no steam hole, whereas the 16cm didn't.
Hand washing them after has been a doddle.
Overall very pleased with the saucepan set and chuffed to bits with the new induction hob!
