9900k Vs 9900ks
9 Jun 2011
My friends 9900k died, he's in the process of buying a new one, are the new batches of 9900k going to be as good overclockin wise? i ask as the 9900ks was announced
Screw the 9900k i'll try convince him to change platform, easy upgrade to 16 cores when it's affordable
And 4000 series next year.....
not sure - think his psu gave in and fried the chip etc. That's why no RMA
CPUs don't get "fried". If PSU died more likely the mobo died also, but not the CPU.
Why you do not use his CPU to your system?
Just tell him it's probably dead and buy it for £20 :p :D
haha! i did test it on mines - dead as can be, as it was overclocked no RMA as it voids terms. Motherboard works??? - tested my cpu in it ( with my psu), also tempted to sell my 9900k now... will the 4000 series have more than 16 coreS?
IIRC, yes but it's not needed. If SM4 comes with it though, it'll be worth it
im to lazy to google what is sm4?
Hyperthreading is Intel's implementation of SMT, so basically think of SMT4 as AMD's Hyperthreading with 4 threads per core, not 2.
But it's very unlikely to be coming with Zen 3 now, so Ryzen 4000 will still be 2 threads per core. Probably stay at 16 cores max as well, but Zen 3 is looking to have a big IPC boost and possibly a tiny clock bump as well. So it'll be even faster than Zen 2.
How would they know it's been overclocked? If no visible signs of damage you can RMA it
Zen 3 won't have SM4, however the whole architecture is improved. No CCX, more L3, higher clocks, new improves I/O at 7nm, more transistors and chiplets made on 7nm EUV not 7nm.
Tell him to RMA the CPU straight to Intel, its worth a go. No way to tell it has been overclocked, i RMA'd directly to AMD in the past it cost me the postage to Netherlands.
