Tweak my basket!
30 Mar 2010
Exile
Hi it's time for a new system!
I want to build my first watercooled rig. I have £2.5k to spend.
I may not need a PSU and have allocated £500 for the watercooled parts.
I would like advice on the parts I have chosen. And whether there are better options or compatibility issues.
I picked the ram and gfx mainly on looks, so I'm sure there are better options.
Thanks
Edit: Forgot to say the system will be an all rounder, used for a little bit of gaming and some photoshop.
me personally i would sack the overpriced sammy nvme and get a corsair mp510 or sabrent rocket and put what you save towards something else.
Any reason for choosing the Asus Blower card when there's (probably) Quieter models that are cheaper? I'm not keen on Blower cards personally as I owned one many moons ago & it made more noise than a Vacuum cleaner.
No reason at all, I picked it purely because it looked cool. Same with the ram.. aww pretty LEDs!
I haven't looked into hardware for around 7 years, so have no idea what's good and what isn't. The items above are a rough guide really.
I will be water-cooling a gfx so need one that I'm able to do that with.
