Hi,
I'm wanting to put together a simple secondary system for old titles and some general use, a kind of back up system if you will. This doesn't have to be powerful at all but if a better component makes sense in terms of VFM then all well and good. It will be a Windows 7 build (for older game compatibility with mods) so, AFAIK, that excludes the Ryzen 3000 series (apart from the 3200g & 3400g)? I'm thinking maybe a micro or mini-ATX is the way to go?
No strict budget as such, just the main unit is what I require, so CPU / mobo / GPU / ram / PSU / SSD, and case.
What do you think of this build? Only a quick first attempt but it's a starting point.
My basket at Overclockers UK:
- 1 x MSI B450M Mortar MAX (Socket AM4) DDR4 mATX Motherboard= £92.99
- 1 x Bitfenix Formula Series 450W 80 Plus Gold Power Supply= £59.99
- 1 x AMD Ryzen 5 Six Core 2600 3.90GHz (Socket AM4) Processor - Retail= £124.99
- 1 x PowerColor Radeon RX 570 Red Dragon 4096MB GDDR5 PCI-Express Graphics Card= £129.95
- 1 x TeamGroup 1TB L5 Lite SSD 2.5" SATA 6Gbps 3D NAND Solid State Drive= £89.99
- 1 x Corsair Vengeance LPX Black 16GB (2*8GB) 3600 MHz AMD Ryzen Tuned DDR4 Memory Kit= £79.99
- 1 x be quiet! Pure Base 500 Midi Tower Case - Black= £69.95
