Is it worth upgrading a i7 980x 2010 build advice please?
20 Nov 2005
Hi,
Please can you give me any recommendations on if it's worth upgrading my pc;
I built my PC in 2010 and its been brilliant, I have had no problems with it and did a fresh install of windows 7 for the first time during the end of 2018. It's been fine since.
I mostly use it for CAD and 3D modelling (cinema 4D). Sometimes games, but very rarely. I spent quite a lot of money with the intention of upgrading, but I never got around to it and the pc specification today is as I built it in 2010.
My son was playing a game on steam (Hell let loose) and I decided to try it as it looked really good on his Ryzen CPU based pc that we built this year. But it was a bit of a shock to see how bad it looked on my pc as I could only run it on the lower settings (pretty obvious it was going to be like that really!). It didn't help that I have bad internet access I this room as well.
So I started to think that maybe it's time to upgrade but realise my options are limited due the age of the PC.
For what I use my pc for do you think it's worth upgrading or doing a new build? I can't really justify the price of a new build for what I use my pc for to be honest, but it's an option.
I thought about windows 10, but I don't think my motherboard will support it.
It takes a while to boot up, but after that everything opens up really fast. So I wasn't sure if a SDD would really be worth it to reduce the boot time mostly?
So, I think all I am really left with is perhaps changing the graphics card?
Most of the parts of my 2010 pc build:
  • Motherboard = Asus P6X58D-E
  • CPU = I7 980X 3.3ghz (not overclocked or want to do that)
  • RAM = 12gb Corsair Dominator
  • GPU = ATI Sapphire HD 6870 1gb
  • HDD = 1TB Seagate Barracuda
  • PSU = Enermax Revolution 85+ 850w Modular
  • OS = Windows 7 Home Premium (64 bit)
Sorry about the long post as I was trying to explain it as best as I can.
Thank you
A SSD is one of the most worthwhile investments you can make.
It'll drastically decrease your boot times and improve application load times - any PC really should have at least an SSD as the boot drive.
A new gfx card - even a modest one like Nvidias 1650/1660 or AMDs new RX 5500/XT due in the very near future will give you a big improvement in performance with games and some plugins for cinema 4d may also benefit from gpu rendering.
Alternatively go crazy and get one of the new Ryzens with 16+ cores and build a new platform which will last another decade :D
Hi Squid Vicious,
Thank you.
I think a SSD would be a good, I had one installed by IT on my work PC and its been fast! On my son's pc we put the OS on the SSD and applications on the HDD, but he only plays games on it. For me, is that the best way to install? To have my software on the HHD and OS on the SSD, or will that defeat the object of the speed?
Graphics card sounds good as well, should help with the viewports on the CAD and C4D as well as games.
I am not 100% sure about windows 10 as I have read that my motherboard doesn't support it, however the ASUS website is showing driver for windows 10 64 bit?
I was thinking about a new build Ryzen, but not sure if I can justify it at the minute. But If I go for a new SSD and GPU at least I could add that to a new build at some point.
The recommended specs for Hell Let Loose are
CPU: i5-7600 @ 3.5GHz or Ryzen 5 1600 @ 3.2GHz.
RAM: 16 GB.
OS: Win7 64bit.
VIDEO CARD: Nvidia GTX 1070 or AMD RX Vega 56.
FREE DISK SPACE: 20 GB.
DEDICATED VIDEO RAM: 8192 MB.
Your PC is far below that; complete replacement is in order.
Which software do you use?
Hi Quartz,
Thank you.
I use Cinema 4D (R11), recently Draftsight CAD, but now NanoCAD (5.0) and general everyday Windows programmes (word etc). Thinking of getting some powerlines as well to help with that.
I got hell let loose to run, but it was laggy because of my bad internet connection and had to lower the graphics settings. I think I would have had a better go of it if my connection was better.
Is my cpu not up to par with those you mentioned?
Your CPU is 6 Intel generations behind. Your software is also old. I'm not familiar with Cinema4D but Google indicates it has been replaced by U-Render which demands a far better GPU:
  • AMD or NVIDIA GPU
  • OpenGL 4.5 capable
  • 3 GB or more of graphics VRAM (8 GB or more recommended)
Take a look at the RX 590 or the upcoming RX 5500 if there are models with 8 GB VRAM.
Good plan.
Hi Squid Vicious,
Thank you.
Windows 10 should install just fine, I had it running recently on a asus p6t deluxe v2 which is very similar to your board. A good time to upgrade with support ending for win 7 very soon.
"I'm not familiar with Cinema4D but Google indicates it has been replaced by U-Render which demands a far better GPU:
Lol, no.
U-Render is one of many optional 3rd party render engines that Cinema 4D can use, like Octane, Redshift, VRay etc - it's a very undemanding render engine mainly used for rapid previews, although you're right that it uses GPU more than CPU.
But it's a moot point, since Cinema 4D itself is now on R21 - R11 is now 11 years old & 10 versions out of date. It will benefit most from single core cpu speed for modelling & animation, multi-core cpu speed for rendering & GPU for handling high-polygon models in the viewport.
I'd also be crossing my fingers it will even work under Windows 10 but if it works under Windows 7, you might be OK.
Source - I use Cinema 4D for a living.
  • AMD or NVIDIA GPU
Good plan.
Yes! My whole set up is old, time flies by and I just never got round to doing anything about it. I bought a perceptual licence for Cinema just before they changed the pricing plans. So never bothered to update after that. The version I have got is more than adequate for my usage.
I haven't heard of u render, looks like a plug-in, I don't think its in my version of C4D? So this shouldn't be a problem with the gpu.
My son has the RX 590 nitro, blue SE version and is a really nice card. I was hoping to get this one on overclockers, but they have recently sold out unfortunately :(
That was my thinking, get some upgrades now which I can use later on if I go for a new build
Ok, thank you. I will keep that in mind. I prefer W7 but was looking at W10 to get up to date. Thanks for the advise about the possibility of it working with my motherboard.
Was a little worried though as there a few mixed reports online about it not being compatible with my motherboard. And thus some things not working with it. I haven't really looked into it in any depth though
Interesting vid:
i7-980X doesn't do all that bad in games (for its age) compared to how it takes a beating in other applications.
Look at the 1660 Supers, good value for money as well and a bit faster than 590s.
Lol, no.
Thank you. I use Cinema 4D as a hobby, so its nice to talk to somebody who uses it for a living. That was also in the back of my mind about windows 10. The last thing I wanted was to run the risk if C4D not working and then end up spending a bomb upgrading that.
OK, so I downloaded Cinebench R11.5 - I can confirm that both the Open GL & CPU tests ran without a problem on my windows 10.
Now Cinebench is a stripped-down benchmarking program based on Cinema 4D, so it doesn't gaurantee the full program will be problem free, but it does bode well.
Unfortunately, I don't think I have my old R11 discs any more, so not sure I can test the full program.
Whack in a x5650 6 core 12 thread cpu can be picked up for a tenner.
Then a ssd and something like a used gtx 980ti which can be had for around £150.
Thank you for doing that, much appreciated :) and will help me to decide if I want W10 or not
Interesting vid:
Thanks, will have a look at that. Think I've seen similar videos where the I7 does quite well against modern CPU's
Remember youll only get sata 2 ssd speeds on that board(intel) ports
The marvell sata 3 ports are slightly faster but tend to be problematic
Still worth getting an ssd though
Thanks. Just had a look at the motherboard manual and you are right, it has two marvel sata 6.0 gb/s ports.
What is the problem with the marvel ports and will I notice a difference in speed if I have my hdd and planned ssd on both sata 2 ports?
Starting to wonder if it might be better to consider a new build rather than put good money into old?
