- 23 Feb 2009
- South Wirral
Following on from my "spec me" thread back in September, https://forums.overclockers.co.uk/threads/sanity-check-ryzen-3600-build.18864100/ I think my motherboard is borked. System has been working mostly fine since I built it, a few BSOD's which I was putting down to immature drivers, however today its really gone **** up. Things started with it complaining about one of the Nvidia DLL's, so I tried to uninstall the drivers so I could then do a clean install - but in doing that, windows kept failing to restart and then started complaining about corrupt system configuration. Every thing I cared about was already backed up, so I decided to just try and re-install windows - however it can't even do that without either a random reboot when it shouldn't or a BSOD. The BSOD messages vary - and googling them just throw up the usual "check your drivers and hardware" stuff.
I've followed the handy troubleshooting guide sticky, so done the following - none of which has worked:
- Updated to latest BIOS
- Removed CMOS battery and power for 20 minutes and then accepted motherboard default settings
- Disconnected everything not immediately needed (single SSD) and tried USB windows install
- memtest has done 2 full scans with no errors reported so far, I'm currently leaving it running to let it burn through overnight.
- NOT using XMP, just normal memory setting and no overclocking.
I don't think its the PSU - its new and barely any load on it.
I had an M2 drive as well as the SSD - installing windows to both has failed. I can't see two drives being faulty.
Thank-you for reading this far. Is there anything I have missed here in trying to figure out the problem ? Been at this most of the day while working and running out of ideas. At the moment its looks like I will have to RMA the board.
EDIT: more things tried:
- Building outside the case to rule out short-circuit
- Different PSU
- Alternating single memory stick and also using the "wrong" memory slot
Overnight memtest results not visible as when i switched the monitor back on, nothing was displayed even though the PC looked to be running. I'll do another run now and leave the screen ON.
EDIT2:
- Tried windows install from disk instead of USB
- Tried a unix install. Resulted "kernel panic" error message while trying to initialise installation
- Very latest BIOS released last night: 7C02v351(Beta version)
Will do a last memtest, but concluding the MB is at fault. Can't see it being anything else.
- Different PSU
EDIT2:
