- 25 Mar 2004
- Fareham
I am having bathrooms remodelled at the moment, basically done, but some of the tile work in the en-suite is not quite up to par.
Ceiling is being caulked shortly so ignore that the gap at the top. Tiles are the same colour but camera doesn't pick that up strangely.
What havoc would I cause if I asked them to try to level out the corner line on these? Plasterboard wall so I think it could cause damage in other areas if the tiles were ripped off and re-done.
The top left one in the corner appears to be leaning forwards a bit, the one beneath that has a lip on it to the one below, and that tile has a lip the one below that. Annoyingly most of the other tiling in that room is fine, but it's the most obvious place to notice it because it's right in front of you as you go in the door.
Not expecting mm perfection here as the tiles won't be perfect, but I feel like more care and attention should have been paid to these as I assume some adjustments could be made before they set. The wall behind them wasn't bad as I recall, reasonably flat.
Full size image: https://i.imgur.com/YGZgyIoh.jpg
