If You Had To Choose (which gpu out of the 2?)
Building my first pc for gaming. Last piece of the puzzle is graphics card. I have a budget of up to £400 for this and want it to be MSI. I am using an i5-9600K cpu.
I'm not experienced in pc building (hence this being my first), so would appreciate reasoning behind why you choose a particular one)
Here are the 2 options for my budget:
1-
MSI 2060 Super Armor OC
Price £390
White and black design which matches my white build, with white rgb msi logo
8GB GDDR6 Memory
Cores - 2176 Units
Base Clock - 1470 MHz
Boost Clock - 1680 MHz
2-
MSI 2070 Ventus GT
Price £390
Silver and black design, does not match colour scheme and does not have rgb logo (I would never compromise performance over aesthetic, but for me this is a negative in comparison)
8GB GDDR6 Memory
Cores - 2304 Units
Base Clock - 1410 MHz
Boost Clock - 1620 MHz
A brief summary in my inexperienced opinion:
Option 1, the 2060 super armor, has higher clock rates and a much nicer look inside my case, however all of my other non-expert friends tell me I would be stupid not getting the 2070, but can't give a good reason why.
Any advice is much appreciated!
1-
Price £390
8GB GDDR6 Memory
Cores - 2176 Units
2-
MSI 2070 Ventus GT
Price £390
8GB GDDR6 Memory
Cores - 2304 Units
