How can you build on a Nest what can be added to it at a later date?Nest then.
1. How does the multizone feature work ? do you need to buy addons ??
2. can smart thermostat be adjusted manually or can they only be used with apps ?
3. my hot water works via the boiler I dont have a tank would I need a addon for that also ?
4. Would i need to buy multi thermostats for each traditional thermostat ?
I'm looking for some info on thermostats and suggestions on what to get and what I would need
Happy with my Tado (in fact just ordered some TRVs) but as already posted, if you buy v3+ kit then you need to pay a monthly fee. Luckily it's just a one-off for existing customers, not sure how it would work if you buy an older kit now
Nest is too expensive in my option I will also need to get a docking station for it also
Tado looks good but I'm not sure I would trust them to not charge for other things later
I'm not sure I would want to pay a monthly fee after spending so much on the kit to start with.
