Thanks for the help and advice! Again most appreciated.
Reminder of Usage
Over the last few days:-
- day (rate 1) usage has been around 9-13kwh per day.
- night (rate 2) usage has been around 50 odd kwh per day, with us turning all units down to INPUT 4/OUTPUT 1 over night seemingly taking it down to about 40kwh.
Immersion Heater
There are two full on mains switches near the hot water tank. One labelled for "day" and one for "night". The day one is off, the night one is switched on. One night we left the night one off, and the rate 2 (night) usage dropped down by approx 5-10kwh.
So my hope is the immersion heater, when it has power via economy 7 (night), heats the water in the tank to a certain temp and then turns off with a thermostat? Because if it's boiling the water for 6-7hrs over night that would be mad! There's hot water in the morning and towards the end of the day less.
Quite why there isn't simply an old fashioned rotary timer where you could move the "teeth" to dictate when to turn the immersion on I don't know. You'd just set it to an hour in the early morning and probably 30 mins mid/late afternoon, done? Rather than all night and no day water heating?
Testing Heaters
Tonight I've turned off one of the storage units (kitchen) completely, and I'll see with tomorrow's readings how that affects it. I can obviously repeat that with each of the four units in question, albeit one is in a bedroom and one in a lounge, where obviously I'm not keen to get the room cold for the 83yr there :/
Age Of Meter
I'll try and grab the SN tomorrow and post it here along with how turning off one of the storage heaters (the one in the kitchen) seems to affect things... I would hope it would drop it down by 20% or so?
Thanks again for the help, it really is very appreciated
