How do I smoke salmon?
17 Aug 2009
Finchley, London
I just made a mistake. I wanted smoke salmon to put on beigels with cream cheese.
Because it's expensive buying wafer thin sliced pre-packed smoked salmon I decided to buy 200g of salmon fillet from the fishmonger at Tesco. And then I was going to slice it thin.
But I got home and realised it's not smoked. It's got the skin on one side and obviously needs curing. Can anyone tell me an easy way to smoke it and is there any way I can do it without taking hours and hours? Also how long can uncooked salmon stay in the fridge?
It's a bit on the wee side for smoking or pickling (gravelax). Try coating it with a 1:1 mix of sugar and salt (about 1 tbsp each) with some chopped dill and leave it overnight.
Or just bung it in the oven and cook it.
There's a reason you feel robbed buying smoked salmon because as said it's time consuming to make unfortunately
Yeah, very true.
I think I'll probably cook it instead. Grill or bake and for how long? And I've seen that it's best to season it an hour before cooking to absorb moisture and reduce it sticking.
Yeah, very true.
Depends on the outcome you want.
Grilling is a good/quick option, do you have a Foreman style grill? I've found they work quite well.
I've even steamed salmon before and had great results, but it really depends on what you intend to do.
Thanks. Well, I'm looking for the healthiest option I suppose. No I don't have a Foreman style grill, I've got a built in electric grill element in my oven. I've been filleting and grilling mackerel which is very easy and tasty. I spread a little olive oil on bacofoil, heat the oil up and then put the seasoned mackerel on skin side down for about 3 minutes and turn it over and crisp up the skin for about a minute. Can I do salmon the same way, season it an hour before and then grill it on foil for a few minutes?
You could.
Honestly I love the taste of just salmon, I might be the odd one out here. Do you have a steamer, even just an on hob type thing? I often cook salmon in that way with no seasoning or basic seasoning from fresh. It tastes great, have it with a good salad or broken up (you can do it by hand, it's very tender and easy to break down) for a pasta dish or something, very healthy to do that way too. If you do grill it in foil the oil isn't really necessary imo, although doing so might result in more flavour.
You could.
Yes, I just bought a stainless steel colander yesterday for the purpose of steaming over a few inches of water in the saucepan, I could do it in that Will it need turning and how long would you recommend steaming it for?
Lid on and just leave it to cook, you wont need to turn it. Salmon is a lovely fish in that regard as when it's cooked you can easily tell by the colour. Some wrap it in foil but I don't find it necessary. Not sure if a colander would work.
I'd pick up something like this, it's similar to what I use: https://www.amazon.co.uk/Tower-Esse...s=hob+steamer&qid=1576873161&s=kitchen&sr=1-4
Very handy for veg and some fish/meat, if you're into healthy cooking I'd say a steamer is a must.
Actually, I've also got an Ikea unfolding steamer insert that I've been using for veg, like the one in this video, although she must have removed the centre post. Do you find the skin is nice enough to eat without being crispy?
https://www.youtube.com/watch?v=zTb51nWt9Os
Also, I like to wrap fish in foil with a bit of lemon and butter and give it a few minutes in the oven, steams it through effectively but also contains all the fish juice, which I then whip into a sauce while the fish rests.
Edit, it works great with cod or similar. While the fish rests, add a load of butter to the cooking juices, brown it up and add shrimp/small prawns to warm through.
A bit of buttery proper mash and some samphire. Lovely, healthy (if you ignore the huge amount of butter!) and really quick and easy to scale for whoever's eating.
Thanks guys. I'd love to add a load of butter, but health wise, the butter would possibly make it less healthy than pan frying the fish.
Aldi, yes, I nearly went there today as I noticed the price is good. Next time! :) .
Tell you what man, there's times I'm feeling lazy and I do just that with a non-stick stone-ware pan and I don't add any kind of oil or butter or jack to the pan.
https://www.amazon.co.uk/Scoville-Neverstick-Frying-Pan-28cm/dp/B06XWZGXRW/ref=sr_1_6?crid=3J97Y22Z74V56&keywords=scoville+neverstick+frying+pan&qid=1576880009&sprefix=scoville+neverstick+,aps,153&sr=8-6
This to be specific, almost anyway, mine is the same but has a handle on both ends.
Never use oil, butter, or anything of the sort in it. Just slap in what I'm cooking and get on with it.
Thanks Gray. That pan looks excellent. Hmm, maybe my Ikea 365+ pan might get away with using no oil.
I watched a video where the guy puts a circle of greaseproof paper in the frying pan because he said it means needing much less oil and so he only put in a drizzle of olive oil and then the salmon.
