- 5 Feb 2009
My PC has been powering down on its own, but only in some games.
It acts just like the power has been turned off at the wall, and I need to wait a little while and cycle the power switch off and on before it will power up again.
This has only happened in three games, though:
Pillars of Eternity II (only once, in a scene with lots of sigils and lots of enemies on screen at once)
Enderal: Forgotten Stories (again, only once, in the crystal forest place)
Operencia (three times now, latest one being just before I posted this)
I had originally put this down to a likely thermal shutdown. I'm only using the stock cooler on my 2600X, and I could well imagine the phsyics in that PoE II scene, with lots of effects firing off at once, was stressing the CPU.
Oh well, I thought, it's only happened once in that one scene and I am planning to get a better cooler anyway at some point.
In Enderal I felt less confident it was CPU thermals. It's not a new game and I can't imagine it being that demanding. But again, it only happened once and it was in an area with a lot of particle effects, so maybe.
But Operencia? I can't imagine this is a very stressful game for the CPU.
I have tried monitoring my temperatures in these games. I've seen the CPU temp sitting regularly at 74C when coming out of a game, which is fairly hot, but not in the thermal shutdown range. On powering back up after the last shutdown, it was reading 66C in the BIOS. Still hot, but not troublingly so.
Of course, I don't know if there are some effects causing higher spikes in temperature that I'm not monitoring. I guess that's possible.
However, with this system I've played many more demanding games that have run fine (27 hours in RDR2, recently played through Rage 2 and Metro Exodus with no problems at all). Why does it seem to want to power down in Operencia of all things? Three times now. This can't be a conincidence, surely?
Any other potential causes than thermal shutdown? Any diagnostics I should run?
