Hey, recently had the misfortune of having my car door lock frozen, even though the key fitted the lock it wouldn't fully turn.
Is there spray I can use to get a bit of grease in there to coat the surfaces?
I've been told spraying de-icer in there to try and clear it will likely make it worse in future as it'll de-grease/oil the lock more.
