- 20 Oct 2019
I have built a pc with 1gbps ethernet but my plusnet hub one will only let it work at 100mbps help me fix this pleas
Start by trying a different cable.
Yes, the Ethernet cable.
A faulty or partially wired (some only have two pairs connected instead of all four) cable can knock a connection down to 100Mbps.
I use a tp link that has worked before with my xbox at 1 gigabit it is a hub one I have a b450 tomahawk max and I don't know about the ethernet drivers I have not installed them but the ethernet port works at 100mbps but it's supposed to be 1gbpsIs it a direct connection to the router? No additional switches or Powerline adapters?
Did your previous PC connect at Gigabit?
Is it definitely a Hub One and not a Hub Zero?
Have you installed the network drivers for the new motherboard? What is the motherboard?
What's 'It'?It says to update the Driver but that doesn't seem to work
