- 23 Mar 2011
Hi All,
Just wondering if theres anything i need to do in the bios etc to make sure my CPU cooler/fans are working as they should be or if i need to consider a aftermarket cooler etc.
Ive noticed on the windows balanced power plan i get the higher idle temperature. If i change it to power saver, it idles a fair bit lower.
Mother board is a b450m Mortar Max.
1 intake 120mm fan, 1 exhaust 120mm too.
Gtx 1070.
Just checking woth core temp at the moment, resetting it and reading the max heat after a game session and it was 95c. The case felt rather warm too when i shut it down for the evening.
Any advice would be appreciated
*also noticed when idle you can hear the fan kick in, and drop off, and repeat randomly
Gtx 1070.
