- 30 Apr 2014
- The Matrix
The two components under the camera icon are getting up to 85 to 90 degrees C when scanned by my fluke IR thermometer, there are also two more under the ssd, as you can see the ssd has been getting hot at about 61 C on idle I did have the gigabyte heat sink on it juts took it off to look at it , I have since moved the ssd to the lower socket under the GPU and its running much cooler now.
The question is should those 2 components be getting that hot, the system has an i7 9700k with a mild overclock of up to 4.3 gig the water loop temp at idle is about 35 C the case has 2 x 200mm fans at the front.
Thanks in advance
Thanks in advance
