Nah, that's been done with vacuum - the side is pulled in as well.
In fact given the loads this would have been under when the ram was operating, I doubt a vacuum would generate sufficient force. I’m more inclined to say the ram has fouled on something inside and pulled it in from the inside.That was my initial thought too, but then the damage from the top and the way the steel is creased seems to suggest it was struck from above. The sides could easily get pushed in like that in the event of an impact, they're only a few mm thick (we had these exact skips at my last job).
I don't think the top damage is consistent with an implosion.
Well, it's the difference in pressure between the outside and inside that generates a force, f=pa after all. But this appears to be a hydraulic crusher, it's going to generate massive pressures inside it presumably, so it's going to be designed to contain that sort of dp.The vacuum doesn't generate any force. The vacuum removes a pressure equilibrium and you would be amazed how little suction is required to do so.
