Hi, spec me a fish oil supplement.
12 Feb 2009
N.Ireland
Hi, I know I should eat more fish but I don't so could you recommend me a fish oil supplement?
Thanks in advance.
I'm veggie but before I was looking at highest epa Content for money, may have used health's pan or some company that was based in Channel Isles, better value than say Holland and barret
Not so sure about fish oil but I've got this absolutely astonishing snake oil I was told to apply directly to my pee-pee with a rough cloth under direct sunlight. It doesn't seem to help my tooth ache but I sure do enjoy it, the neighbor's not so much.
Dosage : 1 to be taken 8 times a day
Funnily enough, I've just ordered 1000 of these as my previous supply is about to run out. If you use the code FIT then you get them for £26.53 delivered.
At the end of the day fish oil is... fish oil.
I personally take 1000 mg capsules, the H&B ones are only 410 and are one of the most expensive.
The ones sold on my protein are good, also 1000 mg with 300 of that being Omega 3, the same as mine which can be bought from your local town, including places like Home Bargains.
