Checking my undervolting figures on a Ryzen 5 1600
18 Apr 2006
Essex
Hello all, using HWinfo64, my BIOS undervolt on an Asus ROG Strix B350-F tell me all cores are running at upto 3.592mhz at 1.238V (out the box was about 1.36v). I think I set a CPU -ve offset -0.11875v and SOC -ve offset of -0.075v, FID of 144 and DID of 8, Core Boost enabled, Global C State Enabled, CPU LLC on high and SOC LLC on Auto. RAM is at 2927Mhz. I can give other settings if necessary.
Then it says that the CPU temp is 26.5C (at idle)
CPU Core Voltage (SVI12 TFN) is 1.119v (H/L/A = 1.125v/1.10v/1.117v)
SOC Voltage (SVI12 TFN) is 1.012v (H/L/A = 1.025v/1.012v/1.016v)
CPU Core Current is 4.157A (H/L/A = 47.804A/1.039A/9.43A)
SOC Current is 7.576A (H/L/A = 11.184A/7.576A/8.146A)
CPU Package Power is 23.135w (H/L/A = 77.4w/21.55w/27.374w)
CPU Core Power is 3.488w (H/L/A = 52.584w/1.169w/10.286w)
SOC Power is 8.454w (H/L/A = 11.324w/7.671w/8.274w)
CPU+SOC Power Is 13.850w (H/L/A = 62.813w/9.206w/18.342w)
Just wondering if this looks as exceptional as I think or if I am reading something wrong. When I tried to overclock, think I got to about 3.8Ghz or possibly 3.9Ghz but didn't want to run it at those speeds/volts/temps (all of which were significantly higher) so decided on mild overclock and undervolt.
Don't want to mess with it much more but really power usage and voltage look pretty low and I was wondering if HWInfo was either misreading or if I can trust it.
Thanks
NB
I will try this again with a TLDR upfront:
Using HWiFO64, which core voltages am I looking at for real voltages? Core #1-6 VID (1.23v) or CPU Core Voltages(SV12TFN/SOC Voltage(SV12TFN) (1.119v & 1.019v respectively) etc. The same question applies to power usage. CPU Package Power SMU (24.753W)? CPU+SOC Power SV12TFN (13.867W).
Basically, I am trying to make sense of whether my undervolt is applied to the out the box 1.36v and is 1.238v or is applied to the 1.238v and is 1.109v. One is good and one is exceptional.
As an aside, I have been running the CPU-Z Stress test for about 20 minutes and am at 100% usage at 3592.3MHz on all 12 threads now. The CPU Core voltage (SV12 TFN) is 1.1v so showing some droop. the Core VID figure is 1.2v so a lot of droop. The CPU and SOC Power (SV12 TFN) is 66.346W and my CPU temp is 52.9C.
TIA
Noughtboy
Just wondering if this looks as exceptional as I think or if I am reading something wrong...surely VDroop cannot be .12v. It is almost like the negative offset I applied to the standard 1.36v is repeated again in the When I tried to overclock, think I got to about 3.8Ghz or possibly 3.9Ghz but didn't want to run it at those speeds/volts/temps (all of which were significantly higher) so decided on mild overclock and undervolt.
Thanks
NB
