- 20 Jun 2004
- Essex
Just had a new light fitting delivered, it’s a metal bowl style light, but appears to be a European fitting with only 2 terminal wires.
Do do I go about fitting this to a UK style ceiling rose wiring? From what I can tell it is double insulated (the 2 squares inside each other on the label), so I don’t need the Earth? How do I tell which is live and which is neutral in the terminal block? What do I do with the earth in the ceiling rose?
Thanks
Thanks
