New build (or rather, system purchase - I didn't build it) and the two case fans are failing to fire up on start up.
Is this normal behaviour? Do some mobo/case combinations boot without spin up and kick in only when temps rise?
Seems odd to me. Also the case is advertised as having white case lighting which isn't coming on.
These are my specs:
Case: NZXT S340 (with x2 NZXT branded fans installed)
Processor: 8th Generation Intel® 6-Core™ i7 8700k
Motherboard: ASUS Z370 Chipset ASUS Prime 2370-PII
Graphics: Dedicated NVIDIA® GeForce GTX 1080 8GB ASUS Turbo-GTX1080-8G (air cooled)
Memory: 16GB G.Skill Trident Z high-performance RGB memory
SSD: 250GB Solid state drive 256GB SK Hynix SC311 SSD
Hard Drive: 2TB 7200rpm Toshiba 2TB P300 Internal Hard Disk Drive/HDD HDWD120UZSVA
Wi-Fi: Intergrated 300Mbps Wi-Fi Card Asus PCE-N15
CPU Cooling: Cooler MasterLiquid 120
PSU: Cooler Master MasterWatt Lite 700W
OS: Microsoft Windows 10 64-Bit
System built by and branded as Yoyotech Warbird i7 Ultra
These are my specs:
just a simple splitter, the passthrough (combining the absent lighting) had not been attached to the 4-pin molex power source. It was hidden round the back of an otherwise very tidy build behind the motherboard plate.
