- 30 Dec 2019
- Deeside, North Wales
Nooby question, I know you can fit a three pin fan onto a MB four pin header, but how do I know which end to fit it to? TIA
While you can easily plug a 3-pin fan into a 4-pin fan header, that does not mean 4-pin header is PWM or variable voltage. Often 4-pin headers are variable voltage, but if it is really a PWM header then pin-2 has 12v constant power meaning 3-pin fan will always be running at full speed. But also just about as often 4-pin fan headers on newer motherboards can be set to PWM or variable voltage in Bios.Nooby question, I know you can fit a three pin fan onto a MB four pin header, but how do I know which end to fit it to? TIA
