Looking for 24" - 2nd and 3rd monitors
21 Apr 2012
Hey all,
I'm looking to add a 2nd and 3rd monitor to my setup.
I have a 27" main screen currently which I may or may not replace in the future and the 2nd screen is very old!
So I'm looking for 2 preferably identical 24" screens. I'm thinking they don't need to be super high spec given they're for reference mostly.
Ideally I need one that will rotate for stream chat and general reference.
I was looking around £100-150 but from the ones on OCUK they don't have pictures of them rotating so not sure they do.
This would have been great for example - https://www.overclockers.co.uk/dell...ync-led-backlit-gaming-monitor-mo-091-de.html
I wouldn't want a TN panel if I was planning to rotate it (actually I wouldn't want a TN panel at all) due to the viewing angles.
Do you have any recommendations for IPS panels that can be rotated?
Ideally I'd like both monitors to be the same to fit either side of the 27" I buy. As cheap as possible without getting something that is awful basically given they're not the main monitor.
I have recently put an order in for a PC that includes a GIGABYTE 5700XT if that makes any difference.
One of the key things I do is stream and create videos hence the want for 3 screens.
Can't go wrong with the dell's
Looks like a decent price on their site right now.
170 euro.
Don't think I'm going to get a better IPS 24" that lets me use it vertical right?
Out of interest is there a better option for the screen that doesn't need to go vertical?
I'd say not but worth checking!
i would pay the extra £10 and get the ultrasharp U2412m if i was buying from ocuk but you can find similar monitors used if you don't need it to be new.
In terms of Euro (I'm sending to ireland) it's 50 euro more.
The 2419h is 170 euro as opposed to £ and the 2412m is 220 Euro
Not sure if it's worth the 50 euro more
