Its not even much more expensive to take it to a real mechanic. I wouldnt let Halfords anywhere near my car.
How did this happen? Negative and positive are different size to prevent this!
It is a bloody car battery for christ sake! He could have fitted it himself. The owners manual would go into plenty of detail of how to do it. Making an omelette requires more thought!
People just have no basic life skills anymore. That's aimed at both the father and the shop boy!
This is a fair point, I changed my first car battery at half six in the morning half asleep and in the dark. All went fine.It is a bloody car battery for christ sake! He could have fitted it himself. The owners manual would go into plenty of detail of how to do it. Making an omelette requires more thought!
Maybe his Dad is too old to be hefting batteries about.
That's not always possible. My Focus had a battery brace that required a really deep 10mm socket that I didn't have. Luckily I had a mate working at Costco where I'd just bought mine from that could lend me his so I could fit it. Not everyone has the tools.
.this will turn into a sn****** comment, but is aptitude to even change batteries something that young mechanics, do not pick up from their parents, or their personal experience.
If the BMW terminals are different sizes, I had never spotted that ... shame on me. ... but on removal I always cut the black wire first.
No one ever bothers but every car for the past 50 years has come with a manual and will give step by step instructions on basic maintenance like changing batteries and light bulbs, how to check oil, correct tyres etc etc. Most of the more premium brands even have the tools in the back to do this.
My father just called, pretty distraught. He took his Skoda Yeti to the local Halfords and paid 15 quid for the battery replacement service (normally the kind of thing I would do if it wasn't an emergency).
They connected the terminals round the wrong way, and now none of the electrics are working. Car starts, no lights/power steering/washers etc.
Sounds to me like they fried the ECU, but could it be a fuse(s)?
They are refusing to admit responsibility, he has a receipt with the service listed on it. He hasn't budged, its been 3 hours of them trying to fob him off now.
Idiots.
I dread to think of an apocalyptic scenario or ww3. Half the planet would get wiped out instantly with the inability to do simple things but that degree in accounting will make up for it![]()
I wouldn't bet on it. My wife's Audi S4 in the manual for rear light bulb change says to take it to a garage. And it's only one screw that needs to be undone!
I haven't checked it for battery maintenance, but with that in mind I suspect it doesn't tell you how to do it.
the manual/handbook for more than one vehicle I've had under maintenance when you go to the relevant entry simply gives you two options for taking it to someone else to do - very helpful.
which is ridiculous like having to take 2 body panels (total of 18 fastenings and needs two people) and a bracket off just to change a simple light bulb, etc.Yeahthe manual/handbook for more than one vehicle I've had under maintenance when you go to the relevant entry simply gives you two options for taking it to someone else to do - very helpful.
A lot of vehicles seem to be designed to make you use a garage for the simplest of thingswhich is ridiculous like having to take 2 body panels (total of 18 fastenings and needs two people) and a bracket off just to change a simple light bulb, etc.
