Nope my mechanical has the cherry MX reds which are supposed to be one of the quietest and they are very loud so I'd hate to see what normal ones are like.
My cheap Chinese also has clones of the reds and they sound the same.
Apparently they now have silent versions but I would take that with a pinch of salt.
I don't understand why mechanical are so popular everyone raves about them. They are imo worse than membrane.
I don't have a membrane in the house anymore apart from a mini one for console and TV use. I use mechanical and decent ones too as they are reds but I would honestly save the cash if I could go back and just buy a normal keyboard.
Stick gaming onto a bottle of water and I bet you people would pay £101 for it vs a £1 bottle of water.
If my keyboard broke tomorrow I have a backup but if I didn't I'd probably spend £50 max on a replacement.
Get the below if you want a mechanical they are all loud so I wouldn't care what switches it uses.
Otherwise spend £20 on a normal keyboard which will be silent.
Logitech G512 Mechanical Gaming Keyboard Special Edition,RGB Lightsync Backlit Keys,GX Blue Clicky Key Switches,Brushed Aluminum Case,Customizable F-Keys,USB Pass Through,QWERTY UK Layout - Black
The above is circa £55
