New case for E-atx board
22 Oct 2008
Lisburn
Decided to hang fire on my Ryzen upgrade until the 4000 series CPUs come out. But I want to get the ball rolling with a new case to satisfy my tech itch.
I'll be transplanting my current sig tech into it. Eatx board, AIO, etc. Can you recommend me a case that's around £80-100 that I can use now and also later on use with a new ryzen setup? I currently have a Corsair 600t which has served me very well for the last 8 years but time for a new case. It's about as big a case as I'd like to go in terms of size.
I modded my case to have 2 front intake 120mm fans as opposed to the stock 200mm it comes with at stock, so I prefer airflow to be good (Mesh front in new case?)
I'll probably be looking to stick my 240 AIO in the case too at the front when I get it so worth having that thought when recommending a case.
Help a Subby decide :D
I have the Lian-Li PC-011. Its a little more than your £100 top end budget, but is worth every penny of the £120. It really is.
How wide is it really? I've got my 600t on a small wooden base I made for it. 600t is about 25cms wide and already hangs off the sides of the stand. Is the 011 really wide?
