- 2 May 2011
- Woking
It says it isn't drawn to scale, so you can't assume it's a square. There isn't enough information.
Nor can you assume that the bottom side is equal in length to the top.
Did you order the Code Red?Nor can you assume that the bottom side is equal in length to the top.
Sloppy from someone who is so meticulous about their desk arrangement(16*4) + (16*5) + (11*11) = 265 ?
Sloppy from someone who is so meticulous about their desk arrangement![]()
The only way to work it out is if you assume the indent is an equal sided square (i.e., 11 x 11).
Other than that the horizontal measurements in the indent are missing
Just as a curve ball, would the correct answer not be "there isn't enough information to calculate the area" when I was in secondary our teachers used to throw curve balls like that in to catch us out
Return to the teacher with a note "My dad said this is impossible to work out unless we assume the indent is square, but assumption didn't get us to the moon"
I think that would be a reasonable assumption despite the fact that the corners aren't labelled as right angles
Two parallel lines will always maintain a constant distance between them. So if the corners were labelled as right angles, we'd know the bottom is 16 wide, same as the top.How would labelling the corners as right angles tell us the lengths of the sides?
More like you definitely cannot assume that because they've gone to the trouble of drawing the '5' side smaller than the '4' side.I think that would be a reasonable assumption despite the fact that the corners aren't labelled as right angles
That's not correct.
Look at this diagram. The bottom and top lines are parallel and all angles are right angles. The bottom line is not 16 units though.
