Spec me a mini ITX build for the office for VM's
29 Jul 2013
Sheffield
So I need a silent as possible ATX build and wondered if you guys could spec me one up,
No keyboard mouse or monitor etc
ATX Motherboard + Case
AIO Cooler for the CPU (if its not gonna be silent enough :P )
Ryzen CPU
16GB / 32GB
1TB M.2 (if ATX boards allow m.2 slots)
and maybe a mini GPU if the cpu doesn't have on board gpu?
Sub £1k would be ideal.
My basket at Overclockers UK:
Total: £285.97 (includes shipping: £11.10)
£748.68
Since it's for VMs and you don't need especially fast cores just plenty of cores/threads (and RAM), I figure the 2700X makes sense at about half the cost of the 3700X.
Does need a GPU. There's a lot of (new) rubbish under £50 (GDDR3) and then GDDR5 above £50. Would honestly get something second-hand from the MM for below £50. Some GTX 1050 or something.
The cooler is quiet and it would match the case.
Those 2 x 120mm fans are daisy-chainable so no need for an adapter to use the total of 3 fans on that board.
Replacing the 2700X with a 3900X 12-core/24-thread would take you to about £1,050 (+ a GPU). Good chance the mobo will have updated BIOS for Ryzen 3000 but it's no certainty.
£748.68
Thanks but been told this isn't powerful enough think the more powerful cpu would be a better shout
