Advice on buying this AMD rig
d|b
d|b
15 May 2007
I would love some advice from you guys on whether this build is good value at £925
CPU: AMD Ryzen™ 7 3700X
Cooler: AMD Wraith Prism RGB
MB: ASUS TUF GAMING X570-PLUS
RAM: VULCAN GAMING ALLIANCE 16GB DDR4 3600MHZ
GPU: XFX Radeon RX 5700 XT 8GB GDDR6
SSD: Crucial CT500MX 500GB M.2 3.0 NVME )
HDD: 2TB BARRACUDA 7200RPM 256MB CACHE
PSU: Cooler Master G750M 750W
Case: Phanteks Black Eclipse P400
Most of the components are new. It seems good value just buy looking at the £££ but are the components an config decent in your eyes? Looking to game at 1440p.
Cheers in advance!
Thanks to both of you for clarifying NVME and terabytes - it happens when I try to post when using a phone without my glasses late at night!
Just to clarify what I meant:
  • You could swap the ASUS X570 (£218.99) for an MSI B450 Tomahawk (£94.99) and save £124. This is a good board often recommended in forums and would run all the listed components with ease.
  • The money saved would allow you to trade up from the Crucial MX500 500GB M.2. SSD (£74.99) to the crucial MX500 1TB drive (£128.99) which would allow you to load more applications and/or games to the fastest drive.
You could stop there having saved £70 or spend a bit more and get rid of the mechanical hard drive completely and replace it with a 2TB SSD such as Seagate's 2TB Barracuda SSD at £219.95 on Overclockers. Financially you'd be £99 worse off but the step up in performance would be significant for everything you used the PC for and it would be future proofed for much longer.
Just my thoughts......
Agree about motherboard being expensive for CPU if at the same time SSD is chosen from minimum level.
Crucial MX500 isn't even NVMe drive but SATA drive. (M.2 form factor doesn't change that)
Also that PSU is cheapo with what looks like C(r)apXon capacitors.
Actually it seems to be EOL/legacy model so likely picked up from old PC.
