This.The difference is huge. Just do it, you're about a decade late!
Actually looks like 3 ssd spots to me
1 removable caddy/mounting plate on the right hand side behind motherboard
And 2 fixed non removable on the left
Ie just screw through
No moving parts in ssd anyway so even without mounting points you can shove them anywhere horizontal or vertical doesn't matter
As long as got a little room for heat to get away
I have shoved them just about any where when ran out of mounts
If that's what you want to doThanks for the quick reply so can I just stick on top of the HDD and should not do any harm?
At the point it shows the disk/disks
Just delete the partitions
Until its one large unallocated space
