Child's car not charging
28 Dec 2003
Aberwristwatch
Any advice on why this isn't charging before it goes to the garage in the sky? Checked all the wires, none seem to be loose.
Charger
Charger goes in here
Mishmash of cable under the seat.
I have a multimeter but will need instructions on how to use it.
31 May 2009
Might be a ridiculous suggestion but I've seen these where the charger fits in both ways, and it isn't always obvious which way round is correct.
Can it reverse?
25 Oct 2006
Skegness
It's 2 x 6v sealed lead acid batteries. There'll be a fuse somewhere in that lot that's blown, likely a blade fuse or possibly a thermal trip.
Find it and check for continuity.
OP
28 Dec 2003
Aberwristwatch
Can it reverse?
No charger connects via one round connector.
i need to re educate myself on electronics ,looks like 2 banks of series 18650s in parallel ,wouldnt that charger need to output over 7.4 volts at least 8.4 ?
probably drunk too much
It's worked for the past 3 years so I'm guessing no.
22 Oct 2002
London Village
unplug the mollex connector in the centre of the picture put the multi meter props on each of the connectors incoming when trying to charge.
if this connection is loose then it wont charge also if no voltage or current at this point the problem is between here and the wall socket.
when it no plugged in put the multimeter probes on the balck and red spade connectors on each of the black batteries packs
13 Sep 2003
Glocestershire
These are the reading I get on the multimeter when I place them on the batteries whilst charging
V~ 200 = 3.5
V- 200 = 2
That seams very low. Is there a label on the batteries stating their normal Voltage.
If you can get your hands on a suitable car battery charger you could try charging them independently (I'm guessing they're 6 volt). This should give you a good idea if it's the batteries or the charging system.
13 Jun 2011
I think the outside is the negative and the inside is the positive.
will be very low voltage so no darwin award.
jam the red inside and the black on the outside. Should get 7.5v dc out according to the label
