For the last couple of weeks my s2000 has developed what can be described as a slight judder/wobble on the brake pedal under braking. It's barely noticeable at braking from around 30mph but a lot more so at 50mph+. Nothing through the steering wheel and doesn't pull to either side. The discs all round from memory are pagid and the pads all round are stop tech. They were all changed at the same time less than 25k on them. Pads still have life left in them from the looks of the depth. Fluid was changed when the lines were done due to corrosion less than 12 months ago.
Any ideas other than sticking caliper and uneven disc?
