Oh I agree, I was thinking more a separate added on EDRAM die of some significant size for caching benefits. I don't see it happening either but it's all I can come up with for a way for them to give a bit of a performance boost to their new chips.
It would improve the IPC in some tasks, where it could cache more branch prediction data, however an EDRAM die wouldn't help with X86 execution, it defeats the objective of an L3 Cache, the bandwidth isn't any where near high enough and with it being external to the core die the latency is too high.
AMD use a huge L3 to get around the latency of having external Memory Controllers, Games move a lot of data around between the L3 and Ram, having an external IMC increases the latency of that which in turn reduces IPC, if your clocking 4 tasks per cycle having a 20ns delay moving that to the IMC bottlenecks the tasks you have executed, using a large L3 to queue those tasks helps stop the core from stalling out, or idling.
An external EDRAM just creates a bottleneck between the core and it and even without that it would only help with large exaction transfers, if you're executing 3 tasks per cycle compared to 4 your core is still slower, AMD's Zen 2 core is faster than Intel's Coffeelake core. Much faster.
