Hi everyone, this is my first post on the forum!
I am wanting to build a custom PC for music production/recording, so it must be absolutely silent or else the sensitive microphones will pick up the noise.
Due to the OS that I wish to use, I am limited to the i7 2700k cpu as the fastest processor that I can use. This is a 95w cpu which I originally planned to use with the nofan 95c heatsink, but as I also wish to overclock this processor to around 4.5ghz, this wouldn’t be enough cooling power.
For the cpu and gpu cooling, I am thinking about water cooling. I don’t plan to use a fan, but instead thought I could make up for this by using a Mazda MX5 radiator instead of a standard PC radiator, I am sure the extra surface size would be a good compromise for a fanless design?
However, I am sure that even the most silent pump would still make some noise, as well as coil whine from all the electronics in the computer such as psu and motherboard parts etc... So I was thinking that I could ALSO submerge everything in mineral oil, also with its own pump and Mazda mx5 radiator! Would the mineral oil completely absorb all the noise from the two pumps, electronics, and coil whine etc?
If so, what are the most quiet and reliable pumps that could achieve this?
I know this seems impractical but there is no other way round it. And I can’t put the computer in another room as I will always need to keep plugging stuff in and out of it, so definitely need it close to the desk.
So basically, it would be a water cooled computer, without a fan but a car radiator, submerged in mineral oil circulated by a 2nd pump, without a fan but a car radiator. So two pumps and two radiators, to achieve effective cooling and silence.
Would this work?
Would this work?
