I've drawn it exactly as it is in the book - makes a point of it not being to scale.
Just a thought, what does the question itself actually say? Does it mention the cut out section being a "square" at all?
If it's a square my answer is 199m2 if this was an exam most of you would have skipped it over a missing number, you can't win if you don't play.
Beat you to it on the First page42.
That's the answer to life and all that jazz![]()
Op never read the question correctly where it clearly states that the indent is of equal length horizontally and vertically and is too ashamed to post.
Seeing that the side labelled 4 is bigger than 5, I'm out.![]()
Where does it state that?![]()
That's part of the test. Get them prepared for the real world.
I honestly think they need to try and introduce "real world" at all levels. It would prepare kids much better than the ideal examples you get in school.
For this question it could go along the lines of:
"These are the foundations cut out by Tom on a Friday afternoon at 3pm. Tom couldn't wait to go to the pub, so made sure he was finished well before 5pm.."
Outrageous - deffo can't have the questions framed like that - you're encouraging white supremacy (you defaulted to an Anglo Saxon name), reinforcing gender roles (male builder) and alcoholism - bad example to set to the kids - not to mention that some kids will have a religious objection to alcohol.
Needs to be more like Fatima, finishing her Engineering project (women in STEM, yay) in order to get to the Greenpeace meeting in her new electric car... then you're onto something!
Meanwhile Vlad the nurse, finishes his shift at the hospital late at 8:15pm and wants to get to his vegan bakery class at 8:30pm, it's 2 miles away and his fixed speed bike averages 9mph in London traffic at this time. Second part can he make it to socialist book club afterwards it's blah miles away and....
I'm glad I finished my tea.
Yeah, could be the distance from point A (Sharif works at an organic farm) to B (daughters football lesson), to C (sons ballet class)...![]()
I'm going with the drawing is not to scale and that's the trick of the question, so ignoring scale I get an answer of 265m2.
16x4 = 64
16x5 = 80
16-11 = 5 (5 is the indent)
16-5 = 11
11x11 = 121
64+80+55 = 265m2
But really this is quite an advanced trig question, to advanced for me to figure out. Make a 16 by 4 square and make 2 triangles of it, so we know 90degs for the right angle(opposite), find the angle of hypoentuse and the remainder is adjacent, remember interior angles must be 180. From half of the hypotenuse draw another line to the opposite cutting your triangle in half again. By this point we should know the hypotenuse and adjacent so use trig and find the opposite of half the hyponteuse and THAT figure should be the figure that's missing from the original drawing.
This gives two possibilities at the moment - the question is flawed or the OP has not given all the relevant information - for example whether the cut out area is a square in that case we can answer it.
That's better described as an equation, not a function. And what has rationality got to do with it?If this wasn't a year 7 question (and assuming we've honestly got all the details) I'd write the answer as:
If the drawing is not to scale the area cannot be defined as a rational number but is defined by the function: 64 + 11y + 5x
If you physically measure it the side of length "5" is shorter than the side of length "4"... I can't see any reasonable way of calculating the horizontal lengths of the middle and bottom sections.
A 16 by 4 square? And that's probably the least confusing thing about this post.I'm going with the drawing is not to scale and that's the trick of the question, so ignoring scale I get an answer of 265m2.
16x4 = 64
16x5 = 80
16-5 = 11
11x11 = 121
64+80+55 = 265m2
