SQL guru required please!
30 Sep 2005
Hi,
SQL Guru required please,
Basically I need the location field in DB2 to be the same as the portdescription field in DB1.
The data is all available to match the records, but I do not have any SQL experience to write the correct query. Hell, I don't
even know how to create the scheduled job lol
I was originally going to code it all in VBScript but when I looked at it, I think a SQL query would do it.
Help!!
Thanks!!
DB1 on SERVER1
dbo.UDT_Port - (portdescription, macaddress)
DB2 on SERVER2
dbo.networkinfo - (resourceid, macaddress)
dbo.resourcelocation - (resourceid, location)
yeah, a little more information may be needed to really help out.
If they aren't linked servers you should be able to use openrowset to use data between the 2 servers.
Is this a one off update or are you going to want the data to be automatically updated on a regular basis?
What I would probably do us use Replication to copy the DB1 dbo.UDT_Port - (portdescription, macaddress) table over to DB2 and it'll keep it updated as DB1 gets changed.
Then it is just a case of updating location on
This may be different dependant on the version of SQL being used:
BEGIN TRAN
UPDATE dbo.resourcelocation t1
SET t1.LOCATION = t2.portdescription
FROM dbo.UDT_Port t2
ON t1.macaddress = t2.macaddress
-- ROLLBACK
-- COMMIT
PRINT @@TRANCOUNT
You'd then put something like this in an SP (Stored Procedure) with a job to kick that off every X minutes
Brilliant, thanks guys
The data needs to be regularly updated, once a day will do
Remember the macaddress is in a different table in DB2 to where the location is set so was unsure how the matching would work
Without trying it(edit it didn't this does), this should work:
DO NOT DROP YOUR REAL TABLES AT THE END!
Code:
CREATE TABLE #resourcelocation
    resourceid VARCHAR(50),
    LOCATION VARCHAR(50)
INSERT INTO #resourcelocation
 VALUES ('1',null),
('2',null),
('3',null) ;
CREATE TABLE #networkinfo
    MACAddress VARCHAR(50)
insert into #networkinfo
values ('1','A'),
('2','B'),
('3','C')
CREATE TABLE #UDT_Port
    portdescription VARCHAR(50),
insert into #UDT_Port
values ('loc1','A'),
('loc2','B'),
('loc3','C')
select * from #resourcelocation;
UPDATE #resourcelocation
SET #resourcelocation.LOCATION = t2.portdescription
FROM
 #resourcelocation t1
 inner join #networkinfo n on n.resourceid = t1.resourceid
 inner join #UDT_Port t2 on t2.MACAddress = n.MACAddress;
 drop table #resourcelocation;
 drop table #UDT_Port;
 drop table #networkinfo;
