Permabanned
- 23 Nov 2019
- Scotland
I've started buying parts for my new HEDT. I'm aiming air-cooled.
The Air case looks nicely built, with even the plastic grill parts well made. The case came with 3 fans, but I'll discard them as I want to get Noctua fans.
Aiming for inflow from the bottom to feed the graphics card (120mm x3)/ Maybe get 2x 120mm just to cover the graphics card so as not to interfere with the front inflow.
Inflow from the front (120mm x3 or 140mm x2) to pass over the mobo & feed the CPU fan. Maybe get 2x 140mm to not interfere with the graphics card flow.
Outflow at the top (120mm x 3 or 140mm x2). Maybe 2x 140mm.
Outflow at the back (80mm x 2 or 90mm x1). Maybe 2x 80mm.
Nothing for the side exhaust as it's designed more for a radiator.
Controlled from the mobo, is that too many fans?
Fan question, I get 4 pin fans. Is that correct?
Looking at the A12x25 for case fans, which voltage do I need to get?
