- 21 Dec 2019
- Planet Thanet
PossiblyIt's not safe to flash BIOS right now, and if he has to, then best to remove the CPU and RAM and drives and GPU, and use BIOS Flashback to eliminate any component fault. Just CPU power cable and 24-pin cable plugged into motherboard, nothing else.
Though it sat in the bios 20 minutes no problem
So assumed a bios flash would be safe
Does the latest bios happen to say what it fixes?
Unfortunately they aren't always specific about what it fixes though
