Hi guys,
Back in 2015 I purchased the below machine from Overclockers and at the time it was fantastic. Since then I've swapped the GTX980 for 2 GTX1080's in SLI which for a time was also great but it now feels like time for a change and I'd appreciate your advice.
My question is whether you think I should upgrade the graphics card to extend its life a little longer (RTX2080S maybe)?
or...
Should I replace the whole system in which case what sort of an improvement do you think I would see if I set a budget of £2k including VAT - I'd want a prebuilt machine from OCUK though - I don't want to go back to building my own.
Note that I'm using an LG 34UC97-S monitor which also feels a little old so I'm pondering replacing that at the same time. Any thoughts on a good upgrade there are also welcome and won't need to come from the same budget.
I mainly use it as a gaming machine and want to be able to pass 60FPS running games at a very high setting at 3440*1440
Thanks for the advice!
or...
"Ultima Finesse Avalanche" Intel Core i7 4790K @ 4.5GHz DDR3
- HD-256-SE Seagate Barracuda 3TB 7200RPM SATA 6Gb/s 64MB Cache -
- OEM (ST3000DM001) HDD
- CA-153-NX NZXT Source 340 Midi-Tower Case - White Window
- MB-634-AS Asus Sabertooth Z97 Mark S "Sabranco" Intel Z97 (Socket 1150) DDR3 ATX Motherboard
- CP-541-IN Intel Core i7-4790K 4.00GHz (Devil's Canyon) Socket LGA1150 Processor - OEM
- HS-022-PL Prolimatech Black Genesis CPU Cooler
- CA-023-SF SuperFlower Leadex GOLD 750W Fully Modular "80 Plus Gold" Power Supply
- MY-083-AR Avexir "Sabranco" Series 16GB (2x8GB) DDR3 PC3-19200C11 2400MHz Dual Channel Memory Kit - White Light
- HD-192-SA Samsung 500GB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3DV-NAND Solid State Drive
- GX-073-KF KFA2 GeForce GTX 980 "Hall of Fame V2 Edition" 4096MB GDDR5 PCI-Express Graphics Card
