- 29 Sep 2010
So I'm building a custom loop for my next build, I have a 240 and a 280 radiator with a D5 pump/res.
I got this all pretty cheap off the MM and the total cost of all the bits including fittings isn't far off a very good aio but will obviously be better performance wise.
Now I'm coming to a decision for the graphics card, at the moment I'm looking at the anniversary edition 5700xt for £320, plus a b grade waterblock on ocuk for about 75. So just shy of 400 in total.
But you can get a nitro for that cost, or a mech for 50 less, 60 less for the powercolor one but don't think the coolers are great on the latter two models.
I essentially want something that will run reasonably quiet (not silent, performance over a little noise) with good boost clocks.
I've never installed a gpu block before but unsure on the warranty situation with the 50th anniversary card if I remove it to fit a block.
There is potential that the blower alone might be okay when undervolted but I've not had a blower since a little 970
so any thoughts on the would be helpful too
