On some phones airplane mode does stop it but GPS is passively received so on some devices it isn't disabled.
Additionally some (usually cheaper or ultra small) devices only work with enhanced or assisted GPS functionality and can't use positioning services in airplane mode.
on all the phones I have had gps is seperate from communications, so you can have the gps on alone which just collects data and does not give out any signals.
so airplane mode has nothing to do with it
Very interesting to see where you are flying over
The big problem with using a phone on a plane is you're traveling too fast for the base stations to keep up with you and the network can get rather confused...
Yup, 3/4G networks can only handle handovers when the phone is travelling under 320kph. Being airborne, the phone can communicate with many more base stations that it should normally be able “to see” because there’s terrain or buildings to block the signal. This causes all sorts of signalling issues for the network and they usually respond by barring the phone from camping on any base stations for a period of time.
