Status
Not open for further replies.
19 Feb 2009
Used Autoglym polar seal over the weekend, quite impressed. So much easier than manually applying wax and the results are practically the same.
23 Nov 2004
My Auto Glym Interior plastic cleaner has run out, so I'm looking to get something else to try. Any recommendations? I used it for all of the plastics/dash/trim on the inside.
Also, the seats have got some stains on from the previous owners. They're not massively noticeable but I'd like them gone. Is my only real option to get hold of a wet Vax machine, or are there some good products I can try first?
Thanks.
21 Jan 2010
Ceredigion
APC works well on interiors, dress the plastics with CarPro PERL or Aerospace 303 (which are two favourites of most people).
Seat stains are easiest to remove entirely using extraction or wet vac, but you can get somewhat reasonable results by scrubbing with a stuff brush and an upholstery cleaner, before drying with a microfibre. This can leave tide marks from product residue, which you can reduce the probability of by repeating the above process with water.
21 Jan 2010
Ceredigion
Magic Eraser is great for ingrained dirt. Makeup, or greasy stains like moisturisers or sunscreen will need a stronger cleaning solution, like a less dilute APC for example.
7 Nov 2011
So, I have baked in dust on one of my front wheels following a sticking brake running down to the bare metal.
This has led to baked on, orange roughness on the face of the alloy. Would an acidic wheel cleaner improve this or am I looking at a wheel refurb? A mate mentioned using a clay bar but, not sure where to start really.
21 Jan 2010
Ceredigion
Multiple hits with fallout remover as a first step. If that doesn't work try clay. If you still get nowhere near removing it, try the acidic wheel cleaner. They can be pretty aggressive, especially on corroded paint or on diamond cut alloys, so always a last resort.
18 Feb 2007
London
Can someone explain what snow foam is, I normally just bucket wash my car with a decent shampoo and soft microfibre sponge.
I have a Karcher pressure washer, so wondering if I can use that for doing this snow foam thing, but what do I need to do it and what are the benefits?
Thanks
7 Nov 2011
Thanking you!
Any particular fallout remover that is recommended? Can I use that across the car or just for the wheels (never used a fallout remover)
25 Oct 2009
Caerphilly
Thanks
It's a pre-clean to loosen and remove dirt basically. Before going at it with wash mitt and bucket method. Lessens chances of swirls / scratches.
You'll need a snow foam (Bilt Hamber Auto Foam) and a foam lance from ebay (£16 - no point spending any more than that).
1 Jul 2011
Oven cleaner works and doesn't seem to damage the alloy
18 Feb 2007
London
I have a few scratches on my car, quite light but noticeable as its a black car, I'm thinking about getting a machine polisher to make easy work of this stuff hopefully.
I have seen the DAS 6 machine polisher, is it a case of then just purchasing the correct polishing pad and polish to get the scratch out, was looking at Meguires scratch X
21 Jan 2010
Ceredigion
Thanking you!
Bilt Hamber Korrosol is good value for money and very effective. Yes, can use across the entire car.
ScratchX is mediocre. Try Ultimate Compound on a light cut or polishing pad, or Scholl S20+ on a Purple Spider pad. You can also try using a glaze or filler polish (like Autoglym SRP) to mask the scratches
18 Feb 2007
London
So would you say the Das 6 machine polisher is ok to use to do this? Ive never used a machine polisher so just unsure where to start. Cheers
@Cookeh
This is what i'm looking at, and it mentions the product you suggestedhttps://www.cleanyourcar.co.uk/das-6-pro-dual-action-polisher-meguiars-hex-logic-kit
Status
