Enthoo 719 Fan Hub
9 Feb 2020
Hello All:
1st time poster with a question. I have the Enthoo 719 case but I am having issues with the built in fan hub. I do not seem to be getting power to it. I think I have the SATA connections hooked up but when I hook my fans to it, there is no power going to the fans. I have tried looking in the manual but it is not helpful. I have tried googling and youtubing it but I can not find an answer. Does anyone have this case and are using the fan hub that they can tell me what needs to be done to hook it up? Thanks
Best I can do this hour of night
Not sure if you can
Zoom enough to
Make sense of it there's awful
Lot of wires
edit sorry am brain dead cant even do the link right
the long link should work
hopefully
view
view
https://drive.google.com/open?id=1E6vtGsQmPi407_J6dQ1h9wH63YIDmmPj
h18gpSJ
open
h18gpSJ
Thanks for the reply but 5 of your six pics are not able to be viewed. The one that can be is just the back of your case open and I can't really see anything
Sorry was after 3am
Was so tired
Couldn't manage to do link right
They were all the same one
Was hoping you could
Zoom in to see something
Are you using 3 pin or 4 pin fans?
I have 3 x 4pin which work
Fine but the 1 x 3 pin isn't spinning
Not sure I remember a
Power connector coming off
The fan hub
Is it possibly pre wired into
The power button?
Sorry was after 3am
Was so tired
The fan hub
The power button?
I am using 4 pin fans. As for being pre-wired into the power button I have no idea.
Sorry not been at home today
To be able to look
Do you have a photo of the
Rear of yours?
Normally with hubs
There's a sata connector
And a pwm wire which goes
To the motherboard
I don't remember a sata connector
When building mine
Or it may be that the sata
Connector is further to the left
And not obviously coming
Off the hub
But as you can see mine had
An awful lot of wires
A photo of yours may be easier
To see and might jog
My memory
Failing that tomorrow I will be
Able to take the back off
Mine and see
Had a look
On the left hand side of the
Fan hub pcb right up
At the top
There's a thin grey and black wire
Comes off it
Follow that and should find
A sata connector I think
I can't see end of mine
As its buried in heap of cables
Behind the cable cover plate next
To the psu
Had a look
At the top
Comes off it
To the psu
Sorry I have not answered, been busy. I am going to be adding some cable extensions tomorrow and I will have a look. I will let you know how it turns out.
I'd email phanteks support, they'll send you a new hub foc, I've had 2 cases in the past where the hubs been DOA.
Turns out the little wire off to the left had come unplugged but after getting it plugged in again, all is working fine now. Computer is even quitter now.
Glad to hear it was a nice
Easy fix
On a side note
When you close the glass door
Do you have to lift it up
A little?
Mine doesn't line up to the latch without
Doing that
Not a major issue but still
Unexpected on a case that
Costs this amount
Easy fix
On a side note
A little?
Doing that
Costs this amount
No I do not have to lift up the door. Did you take the retention screw that holds the door shut for shipping out all the way. If you did then there would be an alignment issue with your door. You may have to contact Phanteks out it.
think i took it all the way out
cant remember now lol
its not worth the hassle of contacting phanteks
to be honest not like i open and close the door very often
was just curious if others did it
