slow deleting of files
6 Oct 2012
(do-or-die) Wye, Ashford, Kent, UK.
sometimes it takes up to 10secs to delete files.
1) i have booted into safe mode and diagnostic mode, and the problem went away.
2) selective startup with microsoft services hidden didn't work, the problem was still present.
3) i have ran avast and malwarebytes scans and nothing was flagged.
apologies if the answer is obvious, but i just do not know how to proceed with what step one showed me :(
There's a few settings regarding this to do with error checking and caching and fragmentation. I can't really remember the details though .
How large are these files and are you doing multiple files at the same time? Where are the files located, on an SSD, HDD or flash drive? Are you already using the drive to access data at the same time? Is it the system drive or an attached one?
it is the main ssd drive.
but the same happens with the second backup internal hd & backup external SSD's.
like i said, i have tested the deletion of the same group of small/large files in three boot modes (safe, diagnostic & clean).
safe and diagnostic are the only ones where the deletion of those same groups of files is not a problem.
the deletion hangs at 99% for 10secs, and i'm positive that never used to happen.
plus it happens with small and large files.
this has only tended to happen when the os is tied up with multiple tasks at once?
Does take a while if tens of thousands of files and going into recycle bin, not straight delete (hold down shift)
there isn't mass deletions of files.
it can be one folder with 500mb or three folder with a combined count of 1gb.
it doesn't matter if it is one folder with a 5mb file, or a folder with a 4gb file, it still takes the same amount of time to delete.
Which anti-malware programs do you have running? Mass deletion of files can be a malware behaviour.
no, i am the one deleting the files, not malware.
I realise that but your AV software will be checking to make sure. Possibly hence the slowdown.
i see what you mean,
i have avast and malwarebytes (both the free versions).
malwarebytes is the one i run manually, while avast runs at startup.
i was actually trying to disable it at startup to test that it was one of the 3rd party programs that might have been causing the issue.
i suppose i could just disable the shields for 10 mins?
a shot in the dark, but possibly the problems started to happen around the same time as i renewed my free version of avast, but my memory is very foggy on the dates.
all i know is that it is related to some progg/app.
