DIY noob - washing machine connection
Caporegime
13 Jan 2010
Llaneirwg
I'm trying to connect a washing machine to where I think it should go in the new house
I've found this
(excuse the to be removed tiles)
And believe one is a hot, one is a cold
I'm guessing I need to figure out which is which by
Turning off the stopcock
Removing the stopper
Seeing if one runs cold and other hot
Put a valve on the end
Connect to washing machine.
Is this noob correct ?
No there isn't
After a Google it seems very unusual but I can't see any other inlet pipes.
There was no washing machine here before. But it's clearly where its meant to be (electrical switch with 'washing machine' to the right on the pic.
Nowadays you just need to connect a cold feed and wastepipe. You might need to get a plumper in to fit the correct connector on the cold one of the two.
Basically, yes. The cold is usually on the right in the UK. But not always as there is no legal requirement to have the hot on a certain side for blind people etc. You will be wanting to get a servicing/isolation valve on there in case you need to disconnect it. Get a 90 degree one so the valve doesn't stick out too much. You should be able to re-use the nut and olive from the stop end that is on there now.
I thought from looking that it looked like the pipe ended with a thread with a blank on the end?
But I'm guessing that's really unlikely brass pipes don't come with such a thing?
Be careful you dont have a flood when removing stop ends. For peace of mind i would call in a plumber to sort it out.
This, or use an elbow then a straight isolater if you cant get hold of an 90 degree one.
Just wanting to make sure there is no way this is something like a brass pipe with a threaded end? With a blank in the end?
Very much doubt that. Its probably a compression stop end
When I thought about it I thought it sounded stupid.
Thanks for help guys .Will report back in couple of days (maybe from my kayak if I flood the house :D )
Id just buy 2 washing machine check valves, remove the stop end, fit the valves.. Then open a valve until it runs hot/stays cold into a bucket and then put the red or blue lever on it to suit.
Thats true, it might be prudent to get someone in to solder some elbows on to it and bring the pipe down the wall. Any any mistakes/accidents with such a small amount of pipe showing could be difficult to fix down the line.
Attempted to take the stop off the end. Found it was octagonal
Nipped to B&q as I have no tools.
Success! Glad I didn't get a plumber in !
This was exactly what I ended up doing.After getting the octagonal stop end off the olive was stuck so I just use what was there
