Upgrade from 4770k to 3700x water block question
24 Jun 2012
Hi,
Regarding the above is it possible to reuse my water block with maybe an adapter bracket, or would I need a new block?
I did read something about adapting it, but I'm not sure it would work in this instance.
Second question this is going to be paired with a 2080ti any advice for a good cheap (ish) motherboard that would go with it?
Any advice gratefully accepted!
Hi,
what make/model is the block ? some EK ones have to get a new block .
depends on your budget , looking for Cheapest Get B450 MSI carbon £115 odd . bit more then £90 for B450 MSI Tomahawk but Phase set up is slightly better along with wifi.
After X570 and have £150-180 to spend then Gigabyte X570 Gaming X or Gigabyte's Aorus Elite mobo
BB CODE
My basket at Overclockers UK:
Total: £491.07 (includes shipping: £11.10)​
elite is quite expensive here. B550 is starting to pick up pace
https://videocardz.com/newz/gigabyte-intel-z490-and-amd-b550-motherboards-spotted-at-eec
BB CODE
It's a xpsc raystorm.
http://www.xs-pc.com/discontinued-2/raystorm-cpu-waterblock-intel
I'll probably go with the x570 for future proofing.
looks like you'll need new Waterblock. Alphacool make their block so they can fit any Socket
Total: £138.64 (includes shipping: £8.70)​
If you have access to a CNC router or a laser cutter (or you're reasonably handy) you could fabricate a new hold down plate. I have an XSPC Delta and I've made a new plate. You may have to source new mounts/screws though so weigh up the benefits.
