- 7 Aug 2004
As title, my Renault master 2013 LWB 2.3 diesel van has randomly started loosing power for a couple of seconds at random times, speeds and hills, it always drives perfectly fine for approx 1.5 hours then the power loss kicks in.
The engine doesn’t cut out, as in stop, but its like....the throttle stops working and the vans engine doesn’t want to make power, i can put my foot to the floor and it wont accelerate, then if i lift it off or drop down a gear it carries on just fine.
I had the fuel filter replaced thinking some rubbish from the filter was blocking it or something but thats not stopped it happening.
It did it today 8-10 times (after approx a 1.5 hours of driving around) for a fraction of a second each time, just powers ‘gone’, drop gear or lift off for at least say....2 seconds then it picks up and works fine again.
When its actually running the engine sounds perfect, runs great, just started doing this and I’m worried it will totally break down or something, I cant have that, I need 100% reliability,
Any ideas?
Any ideas?
