Does anybody have any experience with Heat miser?
I've just installed a wet underfloor system consisting of 10 loops in 6 zones, I will also have 10 radiators upstairs.
I was pretty set on the Honeywell EVO home with smart TRV's upstairs and a traditional flow and return loop for the rads, I want to be able to control rooms that get little use and limit the heating without manually adjusting TRV'S.
My underfloor heating supplier is a Heatmiser distributor and I'm being swayed towards a manifold system upstairs with wall mounted stats in each room, I have the space for a manifold and have open studs so wiring the stats is simple, cost wise the systems are similar.
Just looking for anyone with experience? I had done loads of research on the honeywell but I'm running out of time with 1st fix due to start next week.
