Is the Asus PCE-N15 any good for gaming?
13 Feb 2020
I would like to know if the Asus PCE-N15 will be fine for gaming? The connection I have is 70mb and the pc will be used 75% for gaming and the rest for work. Considering the very low price on this, I'm wondering if everything will be ok or am i better off going for something better?
It'll work as well as anything else assuming you get a reasonable signal and don't expect ridiculously fast transfers over the WLAN to/from other local devices.
I went with one of these
https://www.overclockers.co.uk/asus...00-bluetooth-4.2-pci-e-adapter-nw-10a-as.html
OK it's twice the price, but it's better and has an external antenna, and the on board bluetooth is good for xbox pad.
Frees up a USB port although the Bluetooth has to connect to a USB header on the motherboard.
Wireless AC aswell so more future proof.
I got choppy performance streaming with my old wireless N dongle, this things rock solid.
Looks great and i'll be saving the info for the planned build in a couple of months time; i would have bought the one you
mentioned, but i ordered the other earlier.
